New Beetle PR
http://www.newbeetlepr.com/
Luces Panel Instrumentos
http://www.newbeetlepr.com/viewtopic.php?f=69&t=4245
Página 1 de 1
Autor:  JoRev [ Vie Mar 07, 2014 8:58 am ]
Asunto:  Luces Panel Instrumentos
Color de Indicador: Amarillo
2. Airbag
4. Cruise Control
Color de Indicador: Verde
Color de Indicador: Rojo *
6. Generador / Generator
7. ASR / ESP
10. Luz Alta / High Beam
Color de Indicador: Azul
12. Frenos / Brake
Autor:  José Carlos Méndez [ Vie Mar 07, 2014 10:59 am ]
Asunto:  Re: Luces Panel Instrumentos
Autor:  Ricardo Garcia [ Sab Mar 08, 2014 9:36 am ]
:thumbup: :aplaudir: :clap:
Autor:  Benny 5.0 [ Sab Mar 08, 2014 10:07 am ]
:good:
Autor:  jkv13 [ Vie Sep 19, 2014 2:06 pm ]
http://www.phpbb.com/
